Question about Samsung TL105 ST60 Digital Camera
MY SAMSUNG TL 105 CAMERA LENS KEEPS GOING IN & OUT & DOESNT STOP UNLESS I PULL THE BATTERY
3 Suggested Answers
6ya staff
SOURCE:
lock123
Andrea Lock
  • 6831 Answers
SOURCE: turn on camera the zoom
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 15, 2011
Testimonial: "At first nothing worked but after a few smacks not caring on what if ,the damn thing,came out and it still works great thank you joe."
15073327
  • 441 Answers
SOURCE: Samsung TL 105, turns on, lens starts opening, lcd
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Posted on Mar 02, 2011
How do i print pics from a samsung TL 105 at a kiosk
Just connect the usb cable to your printer only hp or cannon photosmart printer will print your pix directly attaching usb cable select the pix and send to the printing options in main printer menue
Jun 11, 2014 | Samsung TL 105 Digital Camera
Lens problem
sounds like a low battery problem. replace the battery
Nov 10, 2013 | Samsung TL 105 Digital Camera
Samsung 105 camera was in wrong mode and photos were taken in b&w. How to convert back to color?
Sorry, there isn't a way. Once the photo was stored as a black-and-white JPEG file, all the color information was discarded.
Oct 03, 2013 | Samsung TL 105 Digital Camera
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
The lens of the camera was broken by a fall and I want to change it out because the warranty does not cover this damage. how can i disarmed to fix the problem
I will be important to have the estimate on the work with the Samsung service so as to confirm if the work is worth the cost.
It will be important to check the availability of the part prior to deciding the work to be done.
So check this out.
Nov 01, 2010 | Samsung TL 105 Digital Camera
The lens of my samsung is stuck wont go back in. if i press the power button, it turns on for a couple second s then turns off. but it doesnt take pictures. what do i do?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 16, 2010 | Samsung TL 105 Digital Camera
I just bought a brand new samsung tl105 camera like about 1 month or less, i probably used it twice, well now that i turn it on and it shut down on itself right away. What's wrong with it i tried taking...
Hello
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
Sep 07, 2010 | Samsung TL 105 Digital Camera
I'm not really familiar with camera lens i'm just going to write what is written on the lens KODAK RETINAR Aspheric lens 35-105 mm (Equiv) af 3 x optical zoom please tell me how to repair the lens
sounds like the lens on a Kodak point & shoot digital or older film camera- if it is either it isn't worth your effort (unless you want a new hobby)- Sorry, but you should find another camera on eBay
Apr 26, 2010 | Cameras
Samsung TL105 ST60 Digital Camera Logo
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
