I want to use my dvd in another country so that I need to make it region free.
You can get a region free player program on your computer and then you will be free from the region code issues. You could try Leawo Blu-ray Player which is a free Blu-ray player and you could use it to play any DVD and Blu-ray discs.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check this site too.
http://electro-medical.blogspot.com/
SOURCE: how to unlock samsung bd-es6000 DVD Region
Switch on without DVD
Press REPEAT button on the remote
Press 53814 and you should see number 5 on the top right corner -
immediately press 9
(you might have to do this twice)
Switch off this sould make ur player region free.
Thanks
SOURCE: region free unlocking code for LG RH2T80 DVD Recorder
Goto 'Setup'
Scroll to 'Lock' (don't scroll sideways from here)
press '0' seven times
press 'Enter'
SOURCE: region free - Samsung DVD-VR375 DVD Recorder / VCR
I have managed to get a solution to this now. I have a region 4 as in Australia so depending on where you are you'll need to try the correct region. It worked for me first time. Point 4/ below my region code appeared in the top right corner for a couple of seconds not the top left! Once you've completed below turn the machine on again and stick in one of the dvds that would not work before.
Cheers Stewart
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767 or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
SOURCE: changing to multi region dvd
There are a couple sites I found that offer the codes for that player and the BD-P1000. I am not sure if I am allowed to post the links for those sites but the link to the site zimcloud posted is one of the places I saw it listed. You can google the model and region code and a list of sites come up.
Cheers
