The audio amplifier IC are damaged and need to be replaced
Cda-7995 does not produce a pre-amplified signal, the harness coming out the back may have all the colors necessary for your speakers but if you look on the wiring diagram on the cd player it shows that those pins do nothing. You will have two sets of rca's on the back on for your subwoofer, one for an amplifier that will power your regular speakers.
What's a IC and how hard would it be to get and replace it? I hooked up the RCA leads off the back of the head unit to an amp and they work just fine. It's just the normal speaker lines out of the 16 pin plug that do not work. Looks like I'll just run everything through the amp now which will be much more of a pain in the ass but oh well, much better set up now.
