Check all the flat cables that goes from its T'Con to display panel for loose contact. Re-set it at both ends once and check. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: TV freezes at "Philips" screen
a professional. -These electronics go threw a self diagnostic when they start up, normally they turn off when they find a problem.
SOURCE: Flashing red light, screen doesnt turn on
http://recycledpapyr.us/2009/03/26/blown-power-supply-on-philips-plasma/
I found this solution in an other forum , don;t now if you are experiencing the exact same problem though
SOURCE: Philips lcd tv 42pfl5432d/37 no picture
If you feel you have isolated the problem board, you might check here for a replacement:
Jimmy's Parts
SOURCE: No picture on Philips LCD TV
One very common problem encountered on many Philips models, old and new, In some cases, the SSB board has to be replaced as the resistor on the PCB on the back of the CRT had to be fixed. In other cases the Y Sustain board had to be replaced. If the problem is not due to these two issues, then the capacitors will need to be replaced as they only have a fixed guaranteed life. Thus, it would be wise to take out an extended warranty on Philips due to this common repair issue which often occurs after the limited warranty has ended. Or you could just call your local repairman. There are lots of websites on how to fix it yourself on google. There could be many reasons. Hope this helps!
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
