if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
There are two printed circuit boards inside front of toaster - One PC board for each side. The circuit board on the side that won't latch down in the "toasting" position , is defective. Now, does anyone have access to a schematic for this toaster?
On most appliances the knob on the lever pulls off and the cover is then lifted off the lever. Check that the bi-metal strip that latches the toast ejector has not been bent or damaged. Once you have the cover you will be able ot see the whole mechanism.
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
The holder is a bimetallic strip that heats up and opens when it reaches a preset temperature based on the darkness setting. It should latch onto the toast loading mechanism when cold and then snap open when it reaches a certain temperature. The darkness setting knob adjusts the point at which it opens. Probably either the release mechanism is broken or bent or the setting knob is broken. You can disassemble it when unplugged by removing the screws on the bottom and prying off the toast loading knobs by placing a ruler wrapped in cloth against the housing and prying the knobs off with a large screwdriver carefully going back and forth from side to side. If the knobs break or won't go back on use a high temperature epoxy to reassemble. You have a good side to compare the bad side to. Look for differences from one side to the other as the toast loader lever goes down and as the darkness knob is rotated. You may just have something blocking the mechanism. After working on it, plug it in outside to a ground-fault protected outlet on a fireproof surface before attempting to use it.
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
