I CAN NOT USE THEM WHEN I TURN ON POWER IT STILL SHOW "CLEAN UNABLE 5A"ALL TIME
Found you a nice youtube video on that:
Clear Error 46 Unable to Clean on Brother Printers With Numerical Pad
SOURCE: Brother DCP-115C unable to clean
you need a new waist ink absorber box from a service partner which can be found at brother homepage of you country.
After replacing the box you have to do a reset.
search error 46 or unable to clean here in the forum. it has been written many times.
SOURCE: how to do the clean
Hi Good day!! try this method
- Machine off
Switch on the machine while holding down the "menu"button until all the
leds are flashing on/off. Now you are in "maintenance" mode.
- press 80
- press the "mono start" button several times until you see "purge: xxxx"
- press "2783" in order to reset the purge counter. You will see: "purge:0000"
- press "99" to exit the maintenance mode
Now
you are able to print again, but actually your ink absorber box is now
full with ink. Ink flooding can happen if you don't replace this ink
box!
Don't forget to vote thanks!!!!
