Question about Fisher Price Disc for Digital Arts and Crafts Studio
How do i get the needle off - Fisher Price Disc for Digital Arts and Crafts Studio
Skip stitches
some machine are not made to sew thick or heavy fabric
Sewing machine skips stitches
needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Sep 03, 2012 | Brother InnovIs 4000D Computerized Sewing...
How to fix needle on a machine
Turn the hand-wheel counterclockwise until the needle is at the highest point. Lower the guide or presser foot. This will give the maximum room possible for working with the needle.
Turn the needle clamp screw counterclockwise until the needle comes loose. This screw is located on the side of the small
box, known as the needle clamp, that holds the needle in place.
Remove the old needle by pulling it straight down and then angling it outward. Place a new needle into the holding slot or needle clamp.
Tighten the new needle into place by turning the clamp screw clockwise until tight. Do not over-tighten the needle.
Here's a tip
Use a needle that is appropriate for the type of fabric you are sewing. Using the wrong needle may result in breakage and increase the number of needles to be changed
Over-tightening a needle can cause it to be crooked and break. Turn the clamp screw only until the needle feels stiff in place.
here's a link for a manual for the machine
http://www.sewingpartsonline.com/instruction-manual-euro-pro-9110.aspx
Aug 23, 2012 | Euro-Pro Shark 9110 Sewing Machine
Fixing a new needle on a sewing machine
Here's a tip
Machine stitches 2 0r 3 stitch then skips stitches on rest of seam
try changing the needle
Jun 01, 2012 | Janome 6019QC Mechanical Sewing Machine
Zigzag stitch problems on brothers pc-420 sewing machine
1.needle inserted incorrectly
round needle
Correct needle insertion is mandatory for proper use
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem
8.size of needle & thread & the fabric are not compatable
Mar 30, 2012 | Brother PC-420
How to replace the needle bar
There are only a few times when you need to change the needle on a sewing machine. One time is when the needle gets dull and it becomes difficult for the needle to pierce the material. Another time would be when, for whatever reason, the needle breaks. A third time would be when you change from sewing one weight of material to another. Whatever the reasons, changing a sewing machine needle takes only a few minutes to do.
these are the steps....
1.
  • Move the power foot control away to prevent accidently pressing it while changing the needle. Turn the hand wheel that is located on the upper right side of the sewing machine. Watch the needle while you are turning the wheel and stop when the needle is as high as it can go. If the thread is still inserted into the needle, pull it out.
  • 2
    Find the small clamp that holds the needle in place. It is located on the side of the needle bar. Grasp the clamp and turn it to loosen the needle. You don't want to remove the clamp entirely, just loosen it enough for the needle to be removed.
  • 3
    Remove the needle from the needle bar. If you are having difficulty maneuvering to get the needle out, open the needle plate. Be careful when removing a needle, especially if it is broken, to avoid sticking yourself. Set the needle aside, if you are switching out needles to use one for different weight material; otherwise, throw the old needle away.
  • 4
    Select the correct size needle. The different sizes are written on the colored end of the needle that fits into the sewing machine. Turn the needle so that the flat side is facing away from you. Slide it into the needle bar until it reaches as far as it can.
  • 5
    Hold the needle in place with one hand and grasp the needle clamp with the other hand. Tighten the needle clamp. Do not turn it too hard to avoid breaking it or stripping the threads on the clamp.
  • 6
    Clean any thread or fuss that is caught in the needle plate of bobbin case. Turn the hand wheel several times to make sure the needle is securely in place. Thread the needle and continue sewing.
  • Dec 02, 2011 | Sewing Machines
    When it changes from straight stitch to sepintine and back to straight it skips lots of stitches. Just paid $300 for a new shaft.
    try these suggestions & see if they help
    1.needle inserted incorrectly--flat side of the needle faces the shaft
    2.Correct needle insertion is mandatory for proper use.
    7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
    8.size of needle & thread not compatible--
    Sep 15, 2011 | Baby Lock Sewing Machines
    It is a singer quantum futura ce 200 sewing and embroidery machine .the machine sews but incomplete,skipping and missing stiches. does not always bring up bottom thread . grrrrr---help, i want to sew
    Sep 14, 2011 | Singer CE-200 Quantum Futura Computerized...
    Pfaff hobbylock 794
    The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
    "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
    "Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
    The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
    Hope this helps!
    Mar 31, 2008 | PfaFF Hobby 4260
    Fisher Price Disc for Digital Arts and Crafts Studio Logo
    410 people viewed this question
    Top Fisher Price Toys Experts
    Marvin
    Marvin
    NOEL
    NOEL
    yobo007
    yobo007
    Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
