I cant turn off the CC on my T.V. I tried both the remote control cc button and the buttons on the side of the T.V. to turn it off. Although the display states its off, the CC is always on. Is there a way to re-set the defaults of the T.V.?
Just try a reset to this TV. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
Testimonial: "Thanks but I figured out from another posting that my ATT Uverse cable box had the CC setting set to ON somehow, turned it off and the CC is gone."
SOURCE: CC will not turn on....
There are usually several versions of the closed captioning. Cycle through them to see which ones work. Turn one set on...wait a few minutes...if that does not bring up the captioning during normal shows (not commercials)...try the next set.
SOURCE: I cannot turn off the closed caption feature
First, see if your tv is muted. By default, cc comes on when muting that model of tv. Also, you can press menu and navigate to closed captioning and turn it off that way.
SOURCE: Have a KDL-52BR4, cant get rid of closed caption
If you are using a Cable Box, make sure that CC is off. Same applies to a satellite receiver. If you don't have either of those then I would contact your service center to have it looked at. The micro is the only thing that can cause that, providing your sure about how to turn the closed caption off in the menu. Try that way first, instead of using the CC on the remote.
