DB:4.90:Fios Tv Vms1100 Skip Not Working Correctly k3 ... Pressing Play on the remote has no effect, but changing the channel fixes everything. ..... The functions Skip Forward, Skip Backwards, Next Chapter and Previous Chapter all skip ...
Hello
You have hit the channel skip function to on. Go to menu and come towards functions where you can see channel skip. Keep it to "off" position. Now it is in "on" position.
That is an electronic problem. Probably a just-about-to-break cable in the motor of the CD drive, that sometimes causes a short and turns off the unit, or sometimes makes it to comport erratically and produce the buzzy sound. If you have electronics knowledge, then you may open and check the wiring harnesses. If don't, take it to your local electronics repair.
Unfortunately I've never seen a universal remote that will control the extra functions of this. If it's the original SoundDock, you can only do: volume, power, play/pause, skip/scan.
If this is a SoundDock II or SoundDock Portable, you can only control: volume, power, play/pause, skip/scan, and playlist up/ playlist down. Quite honestly, that's all I need to do on my SoundDock. I can't really read what's on my iPod from where I'm sitting in the first place. It may be possible to use a universal learning remote for this, but you'd have to teach commands from an apple remote as well as the bose remote, and the learning remote (+apple remote) may cost you over 1/3 the cost of the SoundDock. It also may not work perfectly. I hope this helps somewhat.
If your lasers eye is dirty the just use a cd/calibrater disc They are cheap and the have a small brush with hairs on the disc that clean the surface of the eye.
