Is it powering on at all? If so, do you see the Dell screen? If you do not see the Dell screen, it's not even POSTing. That usually points to a hardware problem. If you are seeing the Dell screen and it's not loading Windows, that is usually a software issue related to Windows (or it could be bad sectors on your HDD). If you are not seeing the Dell screen, try removing the battery and using only the power cord to power it with. If, however, it is not powering on at all, try a different power cord.
SOURCE: dell latitude d620 bios password removal
To remove a BIOS password will require the assistance of Dell Tech Support. 800-624-9896 You will have to be able to prove you are an authorized user and if out of warranty a Fee may be involved.
SOURCE: I have a Dell d620
Hi It could be any of a hundred things. Your BIOS performs many tests as you turn on the system, if some of those tests fail it will halt the system. However try this...unplug the power, take the battery out and hold down the power button for around 60seconds. This will release any excess charge built up in the machine. Put the power back in and turn on. That's it. You can also then replace the battery. Thank you for contacting fixya.com
Now there will always be various reasons for your screen to fail etc but most will not allow your laptop boot with all lights on and if you hear little 'plink' noises which suggest the laptop has fully booted.
Please get back to us if you have further query else please accept the suggestion.
SOURCE: My dell d620 laptop need a battery, I want buy one
see those batteries:
http://www.discountbatteryshop.co.uk/dell-latitude-d620-battery.html
http://www.battery-center.net/dell-latitude-d620-battery.html
http://www.brand-new-battery.com/dell-latitude-d620.htmhttp://www.laptopbatteryretail.co.uk/dell-latitude-d620-battery.html
SOURCE: Dell D620 laptop screen won't come on after disconnect from docking station
please use the following small secret. Disconnect the power adapter from the laptop.
2) Dissasembly the batteries from the laptop.
3) press the power button in ON with the adapter+battery disconnected from the computer. and maintain press the power button by EXACTLY 60 seconds.This liberate the ESD.
4) Try again.
God bless you
