The set may use the older self check or not:
Here's something that might also be useful. After you turnon the set, and get the regular red blinky lights, hold down the Device andMenu buttons together for about 5 seconds.
The Power light will start to
flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 =
Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 =
DVI cablebetween FMT and Engine disconnected
Also take a look at another problem similar to yours I solved--this also might be helpful:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
