Asus ac68u router is not working with my powerline adapter. The router is brand new and less than a year old. The powerline adapter are tp link 500mpbs model tl-pa411. I have tried directly connecting to the router using a ethernet connection and it works just fine.
HAVE YOU DONE A VOLTAGE CHECK ON THE ADAPTER? IF NOT, READ WHAT THE VOLTAGE ADAPTER OUTPUT IS. IF THE MEASUREMENT IS DIFFERENT OR DON'T GET A READING AT ALL IT MEANS YOU HAVE AN OPEN CIRCUIT ON THE ADAPTER. MOSTLY MOST WIRES BREAK UNSEEN INSIDE THE PLASTIC INSULATOR NEAR THE PLUG END OR NEAR THE ADAPTER END, WHERE THEY BEND MOST.
SOURCE: Networking Problem
When you are connected to your modem, find out what your IP address is....(double click on the icon in the lower left corner of your monitor) under the support tab it will give you your IP address you are being issued from your ISP. Now go ahead and connect the router and then connect your pc to your router. Go to your web based settings of your router....(type 192.168.0.1 or 192.168.1.1 into an open browser window) admin is usually the username and password. From there you will want to go to "status"...make sure the same ip address was assigned to your router as it was assigned to your PC. If not you will have to release and renew to have your ISP re-assign to your new router. Within those settings ensure there is nothing prohibiting you from accessing the internet....your router will have a built in firewall as well as have mac filtering and certain other security settings. Let me know if this helps....once you have done this I will check back and assist you further if this is unsuccessful.
Good Luck
SOURCE: Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
SOURCE: i cannot connect to the internet but network is working...
what is the wan IP in your modem?
What is your DNS configuration?
Cna you successfully run the following command from a command prompt?
nslookup google.com
Does it resolve the hostname to an ip address?
SOURCE: Intermittent WiFi with ASUS WL-500W
I had the same problem. The problem is interferance from other devices. Solution, Change the channel from auto to a fixed one. That worked for me. No more droped connections, and a very strong signal now.
There
are two standards for powerline: HomePlug 1.0, which has a maximum link
speed of 85Mbps and HomePlug AV, which has a maximum link speed of
200Mbps. You can use the two standards within the same building, but
they are not compatible with each other.
HomePlug 1.0 - F5D4050, F5D4070. Powerline Turbo (F5D4071, F5D4073)
HomePlug AV - Powerline AV (F5D4072 + F5D4074 + F5D4077 + F5D4081). Powerline AV+ (F5D4075 + F5D4079) + Powerline HD (F5D4076 + F5D4078) and Powerline HD500 (F5D4085)
