Ws-48311
SOURCE: Mitxubishi WS-48311
si desecha la pantalla puede vender las partes yo me interezo por la parte de la pantalla esque la mia se quebro comun iquese conmigo a dgo-mexico 016188130195 o por este medio
SOURCE: I am having a problem trying to hook up a ps3 slim
try to go to the ps3 settings then go to video output settings , then go to hdmi and it should go black for a min. i didnt think it was working for mine then i unpluged it and there was a big diffrence but it should work
SOURCE: Mitsubishi ws-48311 blue and yellow shadows
I would suggest you go into the menu and select convergence and then advanced convergence (set will display on screen instructions) and call up the grid of lines by doing that---the grid of lines you see should all be yellow---if you see red or blue lines out of position try with the Mitsubishi remote to adjust them.
If they will not adjust the set needs the convergence circuit repaired.
For many if this is the issue it can be a do it yourself repair--I have complete instructions for this repair in this set---start to finish.
Look first to see if this is your problem.
SD TECH
