Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Entered wrong language during intial set up
During the intial set up, my husband selected the wrong language. How do we correct???? Have not been able to find much on this particular problem.
  • Glyn Kendall May 11, 2010
    This page has a graphic of the d40 setup menu options Perhaps you could follow them to set English language. Setup has the spanner icon. Language is one page down. Good luck!http://www.imaging-resource.com/PRODS/ND...
    Sergeant:
    Champion:
  • 248 Answers
The language selection can be found on page 84 of your manual...or if you dont have this enter the menu page in your cam, there is a logo there that looks like a wrench, you can find the language settings there.
Posted on Jul 05, 2009
6ya staff
SOURCE:
Setup the wrong language during the initial setup process. Device will not let me go back and correct the issue. Need to know how to redo the language selection part of the setup mode. The device is no...
Press and hold the Play button until the player turns on.
After the Welcome screen the Main Menu will appear.
Press the PREV/NEXT button to select the Setting mode.
Briefly press the Menu mode button to enter the Setting mode in order to view or change the setup of your system.
Select the [EN] icon (the first icon on the first row).
Dec 29, 2011 | Audio Players & Recorders
HP psc2175 printer accidentally had it's languae changed from english to some other language. When turned on it says "1 Kopie /100%. How do I change it back?
I was able to find this at te hp website:
set the language and country/region
Usually, the language and country or region are set when you install the
HP PSC. If you set the country/region or language incorrectly during
installation, use the following procedure.
1 Press Setup.
2 Press 2, then press 4.
This selects Maintenance, and then selects Set Language & Country/
Region.
You are prompted with a list of languages. You can also scroll through the
languages using or .
3 Using the keypad, enter the two-digit number for the desired language.
4 When prompted, press Enter for Yes or Cancel for No.
You are prompted with all the countries/regions for the selected
language. You can also scroll through the countries/regions using or
5 Using the keypad, enter the two-digit number for the desired country/
region.
6 When prompted, press Enter for Yes or Cancel for No.
7 You can confirm the language and country/region by printing a Self-Test
Report, as follows:
a. Press Setup.
b. Press 1, then press 2.
This selects Print Report, and then selects Self-Test Report.
Apr 20, 2011 | HP PSC 2175 All-In-One InkJet Printer
My Cat sat on the buttons so much that the printer has changed languages to something i don't understand. What do i do to get it back to English?
Hi
Please follow the steps given below to set the right language
To set the language and region, follow the steps below:
On the all-in-one front panel, press the Setup button three times, and then press Enter to access the Maintenance settings.
Press the Right Arrow (>) button three times, and then press Enter to access the Language and Region settings.
The available languages will appear in the display. Press the Right Arrow (>) key to scroll through the available languages until the desired language appears in the display, and then press Enter.
Confirm the selection by pressing Enter again or press Cancel if the language is incorrect to try again.
Press the Right Arrow (>) key until the correct country/region appears in the display, and then press Enter.
Press Enter again to confirm the selection or Cancel if the setting is incorrect to try again
All the best!!
Regards
Oct 31, 2010 | HP PSC 2210 All-In-One InkJet Printer
Closed caption
Try setting your subtitle language to "OFF".
■ Selecting a subtitle language
Select your preferred subtitle language. (The disc must contain the selected language.)
You can also select another available subtitle language during playback with the
Subtitle button on the remote control during playback.
1 Press the Setup button, then press < or > button to select Preference Page.
2 Press ∧, ∨ buttons to select SUB TITLE.
3 Press the Enter button or > button and then press ∧, ∨ buttons to select
your desired language.
4 Press the Enter button.
5 Press the Setup button to resume normal playback.
Note: Supported subtitle languages are English, French, Spanish, Portuguese, German,
Italian, Russian, Chinese, Korean and Off.
Oct 18, 2008 | Akai LCT2721AD 27 in. LCD Television
I accidently changed the language now its in dutch i think
Troubleshooting steps to be Followed
Setting the front panel language on the HP PSC 2200 series To set the language and region, follow the steps below:
  1. On the all-in-one front panel, press the Setup button five times, and then press Enter to access the Maintenance settings.
  2. Press the number 5 on the front panel numeric keypad, and then press Enter to access the Language and Region settings.
  3. The available languages will appear in the display. Press the Right Arrow (>) button to scroll through the available languages. Enter the two-digit code for the desired language based on what is listed in the display (example - 11 for English, 12 for Spanish, and etc.).
  4. Confirm the selection by pressing the number 1 on the numeric keypad of the all-in-one. Press 2 to cancel the language and try again.
  5. The available regions will appear in the display. Press the Right Arrow (>) button to scroll through the available regions. Enter the two-digit code for the desired region based on what is listed in the display.
  6. Confirm the selection by pressing the number 1 on the numeric keypad of the all-in-one. Press 2 to cancel the region and try again.
The front panel language does not set correctly There can be a problem if the front panel cover (bezel) is not installed correctly. If the language cannot be set or is still wrong, do the following:
  1. If the software has not been installed, install it.
  2. Remove the control panel bezel. This may require the use of a coin or small screwdriver to carefully pry up the cover from the back (near the display).
  3. Reinstall the front panel bezel as shown in Figure 1. Be sure the bezel is firmly seated and that all of the buttons can move freely. Figure 1: Installing the front panel bezel c00224430.jpg
  4. Set the front panel language following the steps above.
Sep 18, 2008 | HP PSC 2210 All-In-One InkJet Printer
Language problem
hai
to change the language follow these steps.
Usually, the language and country or region are set when you install the,
HP PSC. If you set the country/region or language incorrectly during.
1. Press Setup.
2.Press 5, then press 5 again.
Region.
the languages using or .
language.
4 When prompted, press 1 for Yes or 2 for No.
or .
region.
6 When prompted, press 1 for Yes or 2 for No.
Test Report, as follows:
a. Press Setup.
b. Press 1, then press 5.
Jul 27, 2008 | HP PSC 2210 All-In-One InkJet Printer
Changing language
Yeah, you can change the language via the Preferences menu. just keep scrolling through the menu until the 'change language' icon comes up and press that. This brings up the choices.
Feb 06, 2008 | Tomtom ONE GPS Receiver
Audio Fragments
Two possibilities: 1. Press DISPLAY during playback. - Use v/V to select an item. The selected item will be highlighted. - Use < / > to change the setting of an item. press ENTER to execute the setting. Change the setting of: Audio language and Digital Audio Output mode Or Subtitle language 2. Press SETUP - LANGUAGE - Disc Language
Nov 28, 2005 | Zenith XBV443 DVD Player/VCR
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
107 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
