Rascal lite way 6 mobility scooter
Http://www.mobilityscootermanuals.co.uk/index.php?route=product/search&search=Rascal&category_id=68
This site seems to have almost all the manuals. This'll get you started.
Hi, it could be battery power , are the new batteries now full charge ? there can be a thermal cutout on the controller mosfets getting tooo hot , and that can be faulty...
Questions to ask yourself, your weight , scooter capacity, condition of charger if batteries are new ...
Regards
Rob
www.facebook.com/gewizrepairs
SOURCE: I AM ONLY GETTING 9.3 VOLT TO THE MOTOR
Just to be sure have the batteries tested with a load tester. Then ohm test the brake. It should be around 35 ohms.
SOURCE: stalling
Check your batteries, they might be ready to die. Stalling is a sign your are not getting enough power to the scooter and when you do, it runs until they run low again. Kinda like a cell phone batt, ones it dies and you wait awhile you can get it started but only for a couple of minutes before dying again.
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
SOURCE: lil rascal stopped again
make sure you hands are not touching the forward or reverse lever when you insert the key. many times if you have your finger or thumb touching the lever just a tid, the scooter will only move a little then stop, or not work at all. this is a safty. Usally I change out the throttle pot and the Key switch (speed pot) together. As for the price, He didn't over charge you if the 150.00 included his labor. Ask if he can replace the throttle if the product is less then 30 days old. But be prepaird to pay shipping and his labor for replacing the first one.
SOURCE: I HAVE A RASCAL MOBILITY
I do not know of a Scooter graveyard, but I will look for one. I found a site that sells many different types of 24volt battery chargers. If you have a special port on the scooter and you still have your old charger you can cut off the end of the bad charger and wire it onto a new battery charger. Now as with most lead/acid battery's any charger with a built in volt/amp regulator will work.Your old charger spect's are for a 4amp max rating, Any constant 2.5amp or better should recharge your battery's overnight. I am sending you a link to a site called Battery Stuff.com where you can find a 24volt charger for as low as $89.oo, Now I understand this may be a bit out of your range, but a new battery charger for a laptop computer will run about $115.oo. So for a Heavy Duty scooter that is not to bad. Plus it may out last 2 sets of battery's. Now use this site as a reference and maybe you can find one you like local. Hope this helps Fixya up.
