If you have an operating system disc that came with your computer try putting it is and see if you can load the disc. If you can go to the repair screen after it loads all files. When you are at command prompt type: chkdsk /r
It will try to repair operating system. When done type "Exit" and restart. If you can't load the operating system disc you might be having a graphics card problem. Go to the manufacturer's website and check on their forums for your problem. Hope this helps
Try going to this link and see if anything there is of assistance.
http://support.gateway.com/s/SOFTWARE/Me...
Try hitting the F11 key on start-up to see if you can get to a restore screen
Otherwise it seems that there is a motherboard issue because it isn't recognizing the hard drive.
Let me know how you make out.
Still not booting. Replaced thermal paste on cpu. Fan is working. Just getting blank screen after initial Gateway screen then all drive activity stops and the only indicator light (besides battery charge and power) is the wireless lighw which never shuts off unless I put the laptop to sleep. I really need help in figuring out this problem to get this running for my grandson.
