Question about Sony KDE-42XS955 42 in. Plasma HDTV
TV used to work correctly. Now turn set on and sound turns on immediately. The picture is blank for 5-10 minutes with several clicking sounds every 30 seconds or so. Then picture appears.
Contact the authorized service centre for Sony. This is not a fault that a normal user can do anything. Electro help
Posted on Oct 22, 2014
SOURCE: losing picture and sound
It needs a new bulb, same thing happen with me. jut get a bulb for this model and change it. if you call sony service, it will cost you about $500.
Posted on Aug 12, 2007
SOURCE: unable to turn sound on, picture is fine. volume numbers increases but still no audio
check menu make sure ,,internal speakers are on,,check rca jacks
Posted on May 15, 2009
SOURCE: Tv Turn sound on, No Picture, turns itself off within seconds
The TV is trying to go on protect mode because an internal fault had been detected. For that reson the protection circuit keeps turning off TV continuously.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also
ensure that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem with no receiver box
or dvd connected.
If that does not work, and you keep having a flashing
led on front of the TV, and tv turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults
that can occur are a blown capacitor on power board, a
convergence IC has blown, or a fault on Digital board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
Posted on May 23, 2009
SOURCE: Sony Plasma TV.
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
Posted on Oct 31, 2009
SOURCE: My Sony plasma tv made a pop sound and now picture is dark.
You will need the y and x sustain boards replaced, possibly the buffers. very expensive repair. you can replace one board but its best to do all of them.
Posted on Jan 22, 2010
Mar 18, 2015 | Sony KDE-42XS955 42 in. Plasma HDTV
Oct 31, 2013 | Sony Televison & Video
Jan 19, 2010 | Sony KDE-42XS955 42 in. Plasma HDTV
Oct 04, 2009 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
Aug 29, 2009 | Sony KDE-42XS955 42 in. Plasma HDTV
May 18, 2009 | Sony KDE-42XS955 42 in. Plasma HDTV
May 17, 2009 | Sony KDE-42XS955 42 in. Plasma HDTV
Apr 02, 2009 | Sony KDE-42XS955 42 in. Plasma HDTV
Aug 26, 2008 | Sony KDE-42XS955 42 in. Plasma HDTV
Nov 29, 2007 | Sony KV-27XBR45 27" TV
244 people viewed this question
