Relay 4G got locked
If you did enter the pin 3 times wrong, you are locked out. Just enter the PUK code, that came with the phone / sim card. If you can't find the card it was on, please contact your provider. In the worst case you need a new sim, with the same phone number.
Testimonial: "Sweet! God Bless your knowledge!Yes Got it unlocked!! Leo"
SOURCE: samsung e-250 i need unlock code
Please follow the instructions carefully! Following are the 12-point instructions to unlock your Samsung E250 phone:
1. First do a CUSTOM RESET by tying in:
*2767*2878#
(Phone may display foreign language – don't worry! The last digits after the * will appear as - - - -; this is normal)
2. Turn off your phone
3. Take the battery and SIM out of the phone
4. Take a wrong network SIM (a SIM the phone does not currently accept) and insert it ONLY HALF way in, so when you turn on the phone it won't detect the SIM. Very important so the phone won't ask for network password and will show "Insert SIM" message.
The process of inserting only half of the SIM. I advice you to take care and do it with a soft approach as you might not have done this before.
5. 2. Now put the battery in carfully behind the protruding SIM card and switch the phone on. The phone must show "Insert SIM" message.
6. 3. Without turning off the phone, now push the SIM card all the way in, at this stage the phone must continue to display the "Insert SIM" message with the WRONG SIM inside.
7. Now make a FULL RESET by typing: *2767*3855#
9. Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
8. The phone should reboot working with "wrong" SIM inside. (Do not turn off the phone)
10. Disable network lock by typing: #7465625*638*00000000#
12. Check this is done with *#7465625#
If your phone is not unlocked please retry the above ensuring all steps are followed to the letter, 9 out of 10 people who have problems have made a simple error and find that when they repeat all the steps it works.
SOURCE: How can I unlock the Samsung Star phone s5230
For the unlock code for your Samsung model mobile,
you can try this site http://www.unlocking4u.com/samsung-s5230-star/rs6wp9/
It has the best instructions and easy methods for unlocking mobile phones.........
SOURCE: want to unlock/jailbreak straight talk samsung
Jailbreaking in IOS is rooting in Android. You root the Precedent (gain access to the root login) by using rtto at http://codegeekbbs.com/samsung.php Just follow the directions you'll find in the file. Just read the Readme.txt file.
Unlocking is making the phone run on other carriers' towers - and you can't do that with a CDMA phone without pretty much rebuilding the phone. (CDMA phones don't have SIM cards, only GSM phones do - the technology is different.)
SOURCE: need my samsung galaxy s GT-i9000 unlock code
dial this *7465625*638*# then type the MNC/NCC code of the carrier want to for your phone .. next type this on the second box 00000000
SOURCE: sim network unlock pin for samsung galaxy s3
I dont think thats the problem, it was in the tablet, I took it out and when I tried to reinstall it I cant figure out if its in right ot not,
