Model r-430cs. 1100 Watts This is a 12-13 year old countertop model that, at that time, was approved by Sharp to be used as a built-in also. The LED "partially" went out about 3 years ago and we kept using the oven. Everything else on the unit works perfect. Thanks
SOURCE: readout on microwave
This is a problem with the control panel assembly, which we repair nationwide for $39.95. For full details, our site is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: Sharp 1100 w Microwave Model R-420BK - Clock display not working correctly
This is a problem with the control panel assembly, and we repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
SOURCE: The number display on my Sharp R-515EK 1200 watts microwave oven
We
regularly repair these control / display units for customers nationwide by mail
for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
information & help.
We're
William E. Miller, AS-EET
[email protected]
Microwave Oven Control Panel Repair Nationwide
SOURCE: Sharp microwave 1200 watts keypad showing
Not a complete answer, but may help describe problem: Our R-510B should be the same except for color, and for several years it has intermittently messed up its display. The left side two segments on the units digit won't light up. So a digit 8, without the two vertical bars on the left, comes out as a letter E reversed left to right. Any digit that uses the two left segments (traditionally labelled segments E and F when talking about 7-segment displays) comes out wrong. Every thing else works fine. I can't tell if this is your problem.
This is almost surely a bad contact at the interface between the LCD display panel and the PC board: Typically there is a "squishy" conductive strip that connects them, and I expect grease has gotten in there. If so careful disassembly and cleaning with a mild solvent should fix it. Since we can live with it, and it usually fixes itself in a few weeks, I have not got around to taking it apart.
Bob Wilson
