For a replacement inverter please see this website:
http://www.partsfortreadmill.com/catalogsearch/result/?q=inverter
Hi Basil, Sorry for the delay in replying, I was confused as to the nature of the issue, If it is a treadmill or inverter issue......This is an inverter problem that you have. To reset the E12 error code you need to turn the power off and then on! This should clear the code!
HI MIKEY , THANKS FOOR YOUR ANSWER.I TRIED MANY WAYS OF RESET, BUT THE ERROR REMAINS..
Is the switch ext set to off?
YES. ALL SWITCH AT INPUTS ARE OFF.NO 3 PHASE MOTOR CONNECTED.DIGITAL OPERATOR SHOWS E12 FIRST , AFTER 3 SEC. 000A AND AFTER 3SEC. 32V AND REPEAT THE SAME CYCLE.
According to the manual, The E12 code is activated when the ext switch is on! To reset the switch must be off then either press reset button or turn power off then on! If you are sure the ext switch is off then could a fuse be blown?
I appreciate your inquiry, friend!
From what you have described your Electrolux washer is displaying an error code of "E12". An "E12" error code stands for a non-fatal reading or writing to the memory. This can be cleared with a reset and you can do that by unplugging the power cord for roughly ten minutes. If this does not resolve your issue it could be a possible problem with your control panel and that may need to be replaced. I hope this information is helpful. -Matt
This code means an error code. That the dishwasher electronic control has detected a condition it needs to check. When you see a code, follow these steps to solve the problem:
· Press "Stop/Clear" to clear the display and stop the beeping if any.
· Reprogram the dishwasher.
· If the code still displays, turn off the power to the dishwasher at your breaker box and wait five minutes and clean all part (area) that are open to water carefully before turning it back on.
Thanks for using fixya
