Posted on Jul 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not accepting disc message disc error c13 - Sony Audio Players & Recorders
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
444
Points
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Jul 18, 2009
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1563140
Points
12312
C13 is usually a motor error, but is dependent upon the model. Can you please post the model number and I'll look it up for you?
Thanks,
Dan
1helpful
2answers
C-13 read error
You forgot to say if it is a C13 read error or a C13 REC error.
Your owner's manual suggests that it is a problem with a dirty and/or crappy disc. Try a different, cleaner one.
JE530 c13
1) It's more likely your laser died than the the drive failed.
2) Run back to your repair guy, and when they fix it (IF they fix it), ask to see it work before you go home. They damned well better fix it for free!
3) Buy another one on eBay.
C13 means the machine cannot read the TOC on the disc. It is possible you have a disc with a bad TOC. You may have left it near a magnetic field, such as a speaker or a component transformer. Try another disc. Or take a disc and erase it, then record on it. See what happens.
2answers
To whoever can help...I have a Sony, RCD W10. I am receiving 2 error codes when I proceed to record a cd. Error code C13 and C14. Does anyone know what this might mean? Simply frustrated
They are what you call fault codes. A fault code provides a machine-readable identifier that can be used to programmatically identify the error condition and respond as appropriate
5helpful
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 • Motorcycles
2helpful
Sony minidisc MDS-JE530 c13 rec error
This could be a solution for your problem, if you get a C13 error it's because of dust on the lens causing TOC read errors. Try blowing out dust using clean compressed air (the kind in the can used for computer maintenance).
1helpful
Doesn't accept md's
The manual says "C13/Disc Error: The system cannot read the disc information correctly. mEject the MD once, then insert it again."
It seems this error turns up when the system cannot read the disc properly, one reason for which is a dirty/dusty lens. Try a minidisc lens cleaner if you haven't already.
Tom
7helpful
2answers
Disc trouble
When i switch on my camcorder, it won't let me record. Error C13-02 is dispalyed on the screen. I have tried 2 different discs and have had no luck. Please help me repairs this.
2answers
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
