This is what they call device interference, You might have to many wireless devices connected to a single USB port on your PC. Sometimes its a struggle between keyboard and mouse both wireless. Solution would be to limit the wireless devices to certain USB ports. For ex: plug the wireless keyboard to opposite USB port from the wireless mouse, vise versa. If you are using a multi-port USB connector, unplug the mouse from the multi-port and plug it to a single USB port on the PC.
SOURCE: in my dell laptop cursor is moving automatically why is it so?
May be your system is infected with soyware and virus.
SOURCE: The cursor on my laptop
what OS, please if windows, use CTRL+ESC to activate the menu, find control panel, by using the arrow keys all the way till you get to the control panel also use the enter key to activate. make necessary adjustment
this should resolve it, vote for when if resolved
regards
SOURCE: Mouse Cursor Jumping while typing causing major typing errors
Reinstall the Mouse Drive rplease and it should work.
Please write abck if you still face problems.
SOURCE: touch pad faulty and cursor
Clean your Pad with a moist wet tissue and dry.
In Control Panel -> Devices manager -> uninstall the mouse/pad driver and either use detect new plug-and-play hardware via the top of the tree in the device manager listing (eg. you Computer name) context menu or simply reboot to force a new re-install of the driver for your Pad and Mouse and see if it solves the problem.
If your Pad is the Synaptic type, install your Netbook driver for the Pad.
Hope that re-installing the driver and Pad utility solve your issue let me know how you go.
ps. Worst case, your Aspire One should still be under manufacturer warranty.
Testimonial: "good quick response. Thank you"
