Need measurements for release fingers for the initial set up for the double clutch.
SOURCE: I just purchased a 2440 john deere tractor it was
would say that your variable displacement pump has rust or other on/inside, it.
Are you using hydralic fluid (not eng oil) in her?
Can you let it run on blocks for a bit - drain and re-fill transmission?
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
SOURCE: need owner's and service manuals for John Deere Model 317/
First off, Mowerman's response was incorrect about the age of a JD 317. They were made from 1979 to 1982.
You can only get manuals either through here: http://techpubs.deere.com/deere/Default.aspx or from a dealer. They're expensive. You can find them on ebay and also here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=317%20Hydrostatic but I haven't used that site.
SOURCE: How do I remove the PTO clutch from a John Deere
Locate and disconnect the power supply cord from the clutch. Remove the bolt, washer and retainer from the center of the clutch, It should now slide off the end of the crankshaft provided you have previously removed anything such as body parts or braces that would be in the way. In some instances penetrating oil must be used to help free it up. When you reassemble it, it is a good idea to use a little bit of anti-seize on the engine shaft in case you have to remove it in the future.
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
