Aastra Telecom PT-392 Corded Phone (PT392) Logo
A
Anonymous Posted on Oct 20, 2014
Check voice messages
How do I check voice mail on the Astra PT 392 phone?
I forgot how to clear the stored voice mails
Les,
If you want to delete the actual voice mails, you have to go through your phone company (using their keypad commands) since voice mail is only accessible through your phone (but the voice mail messages are stored through your phone company provider).
Info from the Uniden DECT 6.0 6035 Manual:
Using the Voice Mail Service If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message LED on the handset ?ashes and VM appears in the handset display whenever you have messages waiting in yourvoice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number and the required voice mail signaling tone. You can use your phonebook to store the access number.
Resetting the Voice Message Waiting Indicator
When you receive a new voice mail message, the new message LED on the top of the handset ?ashes and
appears in the handset display. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state. To reset, press and hold [?nd hs] on the base for ?ve seconds. A beep sounds and the message alert tone is reset.
Here is the manual:
Uniden 6035 1 Owner Manual
4helpful
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 • Cell Phones
How do I set up voicemail? New phone, mailbox says it is full, how do I delete messages?
  • Access the main menu of your Samsung Go Phone. Hold the #1 key down until you are connected to the voice mail system. If for some reason pressing the #1 key doesn't connect you to voice mail then call customer service at 1-800-331-0500. You will be connected with an operator who can help you troubleshoot the voice mail problems on your Go Phone.
  • 2 Follow the voice prompts and select "Listen to Messages" from the list of options. Bear in mind that checking voice mail on a Samsung Go Phone will count against your prepaid minutes.
  • 3 Once you have finished you can select the "Delete Message" option from the voice prompt if you wish to clear your voice mail messages. If not, you can simply press "clear" or hang up the phone to leave the voice mail system.
  • 1helpful
    Voice mail is full - How do we over-ride it?
    If the memory is full it's time to start deleting old messages to free up space. Just listen to the messages and delete them as needed.
    3helpful
    Voice mail message icon won't go away
    first inactive ur voice mail service. then check outbox if any outgoing sms or voice mail r there then delete it.
    VOICE MAIL INACCESSABLE - PHONE JUST RINGS
    Voice mail was down. Called a service tech.
    Voice mail
    Check your voice mail settings are enabled for no anwer/ busy.
    Then check your voice mail number is entered correctly and not disbled by phoning your voicemal
    2helpful
    Voice mail - red light does not work
    Contact your phone company to make sure the stutter tone and/or feature for Voice mail notification is on. I too had the same problem many years ago with AT&T (Then SBC) to correct this.
    1helpful
    2answers
    Change night message
    the night mode message that is being used is the main phone's (phone with lowest Ext. number) night mode message that was customized through it's voice mail.go on the main phone and listen to its voice mail. (voice mail ext. usually 165)continue listening until you hear some options.select the voicemail management optionthen select the change personal greeting optionthen select the after hours greeting optionhope this helps!
    3answers
    Changing message on Comdial Impact Telephone
    Sounds like you are trying to change a voice mail recording. Your Comdial phone can be used on several different Comdial phone systems and with several different voice mail systems that all program and set up differently. Do you have any manuals or instructions for your voice mail system? If not, you will need to find out which voice mail you have and try to locate manuals.
    To change main greetings, etc.. you would need administrative rights to the voice mail. There will probably be a password, hopefully you know it or it's still at default.
    Top Aastra Telecom Lands Phones Experts
    k24674
    Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
