Question about Canon PowerShot S2 IS Digital Camera
Camera shows black in picture mode
My camera shows only a black screen when i put it to take a picture mode. Everything else works fine. When i click to take a picture it also comes out black.
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jul 05, 2009
6ya staff
SOURCE:
I have a Canon PowerShot SX 10 IS. In Manual mode shows only black screen with icons. In Auto mode everything is fine.
Dear Olia,
Just a quick check on your camera. You have a focus issue so check the settings for the ISO - increase the value, eg. 800 or above and reduce the shutter speed. You can do that by the quick access dial (wheel) facing you. There are four direct access menus in a criss-cross direction. One is assigned to shooting mode - single, multi, timed etc. The other direction will have macro, standard, telephoto etc. the 3rd direction will (towards right) will take you to the ISO settings and the last will take you to the shutter speed settings.
you manipulate the ISO and shutter speed and see your screen will brighten up and the subject will be clear. Refer to the picture attached.
Hope this helps.
Oct 18, 2015 | Canon PowerShot SX10 IS Digital Camera
Hi, I have a Canon T2i Rebel. When i put the camera in "M" (totally manual), the image doesnt appear in the LCD screen. Everything else works fine in the monitor, but it is as if the lens where...
That's great news, so let's write it up as a solution so that other people who search on here find the right information!
So it appears that the Canon T2i when in manual mode (M) remembers whatever settings you play with, and that these settings are remembered across power cycles; in other words, turning the camera off, or switching to auto before going back to manual does NOT put the settings back to a default.
This gives you the opportunity to set choices that make the screen view totally white or totally black, and unless you realise what you did, you can fear that your camera is broken in some way. At first, I thought this was a user interface flaw, but at least with the screen black or white, you know which way you need to go to get your picture back! The settings that affect brightness are Shutter Speed, Aperture Value, and ISO Rating. They are accessed in manual mode with the thumbwheel, alone, with Av, and after pressing the ISO button, respectively.
One more little bit of trivia: when in manual mode if you don't have live view on, when you half press the shutter, a little indicator comes up on the exposure scale, so that you can see how the settings you've chosen are going to come out.
P.S. I noticed that there was a forum especially for your camera, you might like to join it, it's called t2iforum dot com.
Jan 24, 2011 | Canon EOS 550D Rebel T2i Digital Camera
When I turn the camera on and look through the viewfinder, it's black. Also, if I flip open the little screen, it is black. It does show the little icons, but it's as if the lens cover is still on (which...
I have the exact same problem.
It started with the recurring "change batteries" problem - which was solved by using non-rechargeable batteries.
Now everything is working fine except there seems to be no light coming through the lense. Everything except reviewing mode is black and all my pictures are completely black. I dont know where the problem is. Could be the ccd. Might take this to the camera shop but im expecting it will cost over $100 to fix... any help?
Jan 13, 2011 | Canon PowerShot S2 IS Digital Camera
Camera turns on fine. I could view picture and all. Just that when I switch to camera mode a video screen is blacked out. Why is that?
Your have a "Display" button that toggles thru different display modes .. one of the modes turns off the LCD backlight .. that useful if you are in bright light and dont need the backlight .. you have a very nice "transflective" display that works great in bright light without the backlight ... you can get more shots with the backlight turned off on each battery charge .(about 25% more) .
so each time you operate the display mode button you will get a different display .. one shows a hystogram .. one turns off the backlight and one puts the camera in a normal mode ..
if everything is working right then even with the backlight turned off you should be able to go outside or any brightly lighted area and see the picture on the screen ..
Sep 04, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
No image on Cybershot DSC-T1
It is known problem of bad ccd imager in Sony DSC-T1 Cyebershot camera and ccd imager will be replaced.
Sony will repair this camera free of cost for ccd imager problem as per announced scheme. You will be charged $20 for shipment.
Click Sony CCD Imager Support fro details.
Apr 12, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 | Cameras
Kodak easyshare DX 7630 screen black in take a picture mode but is fine in review etc
Hey Wistra,
You could try resetting your camera to the factory settings by choosing the reset to default setting in the menu. If this doesn't work the sensor on the camera is most likely broken, and you should have the camera looked at by an authorized service technician. If the camera was purchased less than a year ago the repair would most likely be covered under manufacturers’ warranty. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Kodak EasyShare DX7630 Digital Camera
Pictures Are All Black
I just posted a similar question I have a olympus Fe-110. I can see old pictures through the view screen, but when change the setting to take a image its all black.
Thanks
Nov 10, 2007 | Olympus FE-110 Digital Camera
Pictures are black
If you can display pictures in playback mode but screen is black in capture mode then the CCD sensor has stopped working and needs replacing.
Sep 12, 2007 | Kodak EasyShare LS443 Digital Camera
Nikon S6- LCD screen black
I have The same problem with my S6, and was wondering if you found a solution? Ive done everything but contact Nikon or a camera shop.
Apr 16, 2007 | Nikon COOLPIX S6 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
233 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
