My Delta 23-197 variable speed grinder will not run. Only tried it once and it's been put up for a couple of years. Will not start. Light comes on. Has power
It's possible that the variable speed control may be the issue with your Delta 23-197 grinder. However, before attempting to bypass it, there are a few other things you can check.
First, make sure that the grinder is properly plugged in and that the power outlet is functioning correctly. Check the power cord and make sure that there are no cuts or breaks in the cord.
Next, check the switch and make sure that it is properly engaged. If the switch is faulty, it may need to be replaced.
You can also check the brushes on the motor to see if they are worn out or damaged. If the brushes are worn out, they will need to be replaced.
If none of these troubleshooting steps resolve the issue, it may be possible to bypass the variable speed control. However, this is not recommended unless you have experience with electrical wiring and understand the risks involved.
If you do decide to bypass the variable speed control, you will need to identify the wiring that controls the speed control and connect the wires together to bypass the control. However, keep in mind that this will result in the grinder running at full speed all the time and may shorten the life of the motor. It's always best to have a qualified electrician or technician perform any electrical modifications to your tools.
