What is the parring numbers for the proscan 32?
Try www.proscan.com web sitefor list of paring codes.
SOURCE: Looking for a working remote code for a ProScan
Someone else on the web used 627 and I just tried it. It works!
SOURCE: Proscan 32lb30Q. I need to hook up wireless
You can buy a digital to analogue converter that connects to your COAX digital output and then connects to you RCA jacks. They run around $75. The only problem I've encountered is the DVD does not work through the COAX output, just TV. I'm looking into it.
SOURCE: remote code for a tivo remote
This link helped me. I used the RCA codes. The first one only worked for power and volume but the second code also worked for mute. I have a proscan 32LC30S57. Tried 0001 then 0011
SOURCE: I have a Proscan 32
You will have to order it from Proscan. The part# and web address should be in your owners manual.
