Cars & Trucks Logo
A
Anonymous Posted on Oct 20, 2014
I need to know which wires go to which on a 2000
I need to know which wires go to which on a 2000 Toyota Celica GTS, Head unit is a Kenwood KDC-210u. Help asap please!
Timllfixit
Level 3:
  • Cars & Trucks Master 2,210 Answers
  • Posted on Oct 20, 2014
Timllfixit
Level 3:
Answers
2210
Questions
0
Helped
485185
Points
5787
Kenwood wiring diagrams are usually on Kenwood website. You just need a jumper harness from the Toyota plugs to your player. A good local ICE shop or car accessories shop could help. Try EBAY?
1 Related Answer
Anonymous
  • Posted on Sep 06, 2008
SOURCE: 2001 Toyota Celica GTS Clutch
i paid a friend to do it because it's a lot of work! if you haven't already treid to or got it done just know that when my friend did it; it took him like 8 hours (he'd never done one on a celica, but had done them on american cars) so if your not familiar with it... not a good idea to do alone. I watched him do most, but i'm not the best to talk to about it.(plus i have a 2000GT) Some of the parts that i can remember that he took out to get to the clutch were the front driver's side tire, the axel on the same side, ....some other parts in there....and ALSO parts on top...the intake also had to be taken out just to have enough room to do the job. parts are cheap...just ask for a clutch kit at auto zone or whatever. around $150. another random tid bit that might help is make sure to tighten the engine mounts really good afterwards or else it will jump around in there when you turn it on and cut it off. buy gear oil before you start as well because you will need to put some in after the new clutch is in. i will need to put the car on a real lift... you need a lot of space underneath and on top to work. and most likely two people. well hope some of this helped.
Door ajar light stays on intermittently... 2000 celica gts.
Bad door switch bad adjustment or loose wire.
Try to determine which door and go from there.
00 celica gts timing chain problems
The timing chain should not routinely need changing, but perhaps the tensioner does.
Try first to eliminate any other causes, like the bearings in the fan, drive belt idlers, or alternator. A useful tool is a long screwdriver which you can apply to the various areas while placing your ear to the top of it while the motor idles.
Be very careful to keep clear of moving parts like fan blades.
2helpful
WHEB TO CHANGE A TIMING BELT FOR A 2000 TOYOTA
Never as it does not have a timing belt but instead has a timing chain that requires no maintenance and should last the life of the engine.
2000 Toyota Celica GTS headlights out
The globes filament for low beam are most likely both blown . Check if the plug is getting voltage when the low beam is on or buy a replacement globe and check if this is the case.
How do you know both low beams stopped at the same time ?
They most likely blown at different times but you notice it when both go out and you have zero light. Had this happen to me on a ford falcon EA . Was the globes.
Try not to handle the glass on the replacement globes if Halcyon globes .
Toyota Celica gts 2000 blowing cold air when heater is on.
nothing try back flushing heater core, they clog up due to litle water preasure,you might want to flush cooling system if you already havent, hope this hleps.
2answers
1985 convertible celica fuse location
Check the harness connections located inside r-rear trunk panel. You will find power top motor & wire harness there.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
