Technical numbers remain on my viewing screen after I press the reverse arrow on the back of the camera. How do I delete it so I have a full picture?
SOURCE: Pictures Remaining number change after I take a picture
The file size of a picture depends on the resolution you choose and the complexity of the scene. A picture of blue sky has a smaller file size than a picture of autumn leaves. If the Pictures Remaining number does not change when you take a picture, it generally means that the picture does not take up sufficient memory to decrease the number. This is normal. The number is not a count of consecutive pictures; it is counting available space - the approximate number of pictures remaining.
SOURCE: black screen when in picture mode cant take pictures
PER007 in solution #3 is correct.
I had the same problem with my CoolPix5400 and this resolved the issue.
SOURCE: Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
SOURCE: Black screen
Hi
Dangold have you tried pressing the "Disp" button? It's possible your camera is in 'power save' mode and the LCD is turned off to save battery power.
Can you take pictures even though the screen is blank? If you take a picture can you review it on the camera?
If you can take only solid black pictures then your lens aperture is stuck closed or your CCD is bad, and the lens will have to be replaced.
If you can find a good but defective camera online, you can use the two to make one good one. If you would prefer to have it repaired, I know there are a few places here and there that charge a reasonable amount, and many that do not.
I have been building an affordable digital camera repair business (Google: darntoothysam) for several years now, if you do need a new lens let us know, we can do the repair for only about $70!
Feel free to contact me, and even if you don't use us PLEASE don't pay somebody $150 to fix your camera!
Good luck from Darntoothysam com
Thomas
SOURCE: Sony DSC-T700 PURPLE FLICKER
Let's try Initializing the Camera.
If you're able to access the Home Menu select the SETTINGS in the Home menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize option under the MAIN SETTINGS to initialize the Camera.
If the issue still persists try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists service of the Camera is required.
Control Panel Help Button
Your system's control panel provides you with information and troubleshooting help. When an error or warning condition occurs, the control panel displays a message informing you of the
problem. In many cases, the control panel also displays an animated graphic showing the
location of the problem, such as the location of a paper jam.
To view information about how to fix the problem, press the control panel's Help button,
which is labeled with a "?" symbol. You can press the Help button at any time to get additional
information about the message or menu displayed on the control panel.
PhaserSMART Technical Support
PhaserSMART Technical Support is an automated, Internet-based support system. Use your default web browser to send diagnostic information from your printer to our web site for analysis. PhaserSMART Technical Support examines the information, diagnoses the problem,
and proposes a solution. If the problem is not resolved with the solution, PhaserSMART
Technical Support assists you in opening a Service Request with Xerox Customer Support.
To access PhaserSMART Technical Support:
1. Open your browser and go to www.phaserSMART.com.
2. Enter your system's IP address in the browser window.
3. Follow the instructions on the screen.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
