TV is hooked up to Cable and DVR
Do a hard reset or Factory reset to this set, and check. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: Sony Bravia and Comcast MY DVR Not Working Now
Greetings...
Is the Comcast box digital? and is it a Scientific America 8000 series box?
If so, try unplugging the power to the cable box for a minute, replug and after the reboot see if that fixes the problem...
Ed
SOURCE: No Picture and No Sound on all Analog Channels
Ur tv shouldn't set in cable mode, if u don't have pay cable,or satalite,extra..Should set in air channels.Buy a digital antena or out side roof antena u get all the channels airs.
SOURCE: i have a sony kdl-52S5100,and every so often when
I work for comcast have seen 2 kdl 5100 with same issue changed to component cables issue resolved
hdmi input is the problem. Yes I did try 3 different hd boxes same issue problem is with tv .
You are obviosly the third customer with this problem
SOURCE: my tv is plug into
Do you subscribe to cable television? If you do, you will need a cable box to decode the signal, otherwise unless your local provider offers a free to air service, your TV will not be able to decode the cable signal. It is important to know wether you are connecting your TV to a cable socket, or aerial or satellite, as these are all very different signals which your TV may not decode.
