How to plug a wireless mic into a karaoke system
SOURCE: Set-up wireless karaoke Mic.
Thanks, so much and I already kind of tried that. What I mean is that... it does not have the standard output RCA cable, instead it only has a one prong cord (it is a larger, headphone (like) cable with one big prong on each end). I tried to plug it into the headphone (output) on the JVC which of course didn't work. This is the only place to plug directly into the stereo JVC receiver. So I went to Radio Shack (they are so not techie), they talked me into a stereo to mono converter. It converts from the one big prong to the 2 red/white RCA prongs. I plugged the one prong end to the Trident Mic receiver, then took an RCA cable and plugged that into the other end of the converter then into the DBS port on the JVC receiver, turned everything on and ta da nothing. However, I wondered about the color scheme and the Radio Shack guy said it didn't matter. I will go home and check the connection. I was pretty sure that I had to do something with the mode (your analog/digital comment). I will go home and check that, too.
Thanks for posting. It sure seems like it should work pretty easy, but so far no go.
I will post back, in the meantime, if you have anymore suggestions, please be sure to post.
Ciao and Much Appreciation,
Beth
