GE over counter "sensor" microwave oven inside bulb where food goes
Remove 2 to 4 screws on top that hold the grille vent in place. (Note: in some GE MWO's there are 2 screws accessable from the front of the grille vent). Remove the gille vent. In most models, there is an access door or cover that can be removed by removing 1 screw. Then you should be able to get to and replace that light bulb. Note: Again, some models are different, and there is no access panel or cover. In those MWO's, you have to take the microwave down and remove the whole outer panel to be able to get to the light bulb. Pretty poor design!
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
