I have severaltypes of lens that fit my Pentax k1000 and Me Super Camera. Can I get a Pentax ditigal camera that the lens wouldwork on?
SOURCE: Pentax Optio 50 Digital Camera Lens Error
Not really, it sounds like the lens has been bumped while it was extended. Unfortunately, the "buzz" you hear is the gears stripping one another. The only fix is to have the lens assembly replaced, which usually costs upwards of $200. I see this problem at least 3 times a week in my shop.
SOURCE: Pentax Optio 60 LENS
The same thing happened with my camera, I gave it to a freind for her husband to look at it. He said when turning on face the lens side down (to the ground) when turning off hold lens side up right (to the sky). this worked for mine. I don't know if he did anything else to it but when I zoomed I got lens error. I did what he said and it took several tries but it did work... please post if this helps you.
SOURCE: Pentax Optio M20
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
SOURCE: Pentax K10D won't work with lens from Pentax K100 (film0
The lenses are probably manual focus lenses,
Try this and everything should work fine.
If all this hasn't worked then try seting the mode dial on the camera to M manual mode.
Cheers
SOURCE: Sony Super Steadyshot DSC W80 and lens keeps going in and out
Hi, Focal lens out of sync. camera cannot initialise. Lens requires manually resetting. If you in the U.K , I can help you out.
p.m me at [email protected]
