A pneumatic paint sprayer is the normal description for an airless paint sprayer having an air (pneumatic) motor. For many paints you probably don't have to thin the paint because it is likely that the sprayer will output at least 2,000 psi. The output pressure is the inlet air pressure x the ratio; eg a Graco King 45:1 will take up to 90 psi of air which will provide 90 x 45 = 4,500 psi at the pump. You might have a sprayer with a 23:1 ratio that gives a lower pressure. The other issue with any airless sprayer is its ability to suck in the paint; if it is very thick it may not be able to do it, if the pump displacement is small, but if it has a large displacement like the King 45:1, it will suck in almost any non textured paint. Many DIY airless sprayers have very small paint pumps so they cannot suck in heavy paints, which are normally for industrial use.
You did not mention what paint, you did not mention what sprayer.
remember, if you use solvent - opacity of the paint is sacrified, tints are less visible, metallic require more clear coverage.
for water based paints - except airbrush, usually no thinning is required, but you need to first stir it well (at least 3min on manual or 1min 30sec if mechanical stirer is used) strain it, i am using old stockings for that purpose in single layer, works very well for me and if nozzle is above 1.4mm up to 2.8mm there is no problem whatsoever. if this is splatter paint (nozzle 4.5mm or greater) do not even think about thinning it...
for acrylic - if nozzle is between 0.8mm and 2.8mm, procedure as above and you need to add specific thinner, usually up to 20% albeit in some cases up to 40% per volume) so paint will be about like ight cooking oil - water.
for oil paints and enamels - solvent should be not more than 20%, albeit you can increase it up to 40% in rare circumstances, if you are using hvlp gun, you can, if you yousing hp gun - no! it will disperse too much.
for two packs and urethanes - not more than 20% better keep between 5% and 10%
for latex - in rare circumstances you are allowed to use very, VERY specific solvent, and ususally not more than 10%, nozzle usually is 8mm or greater in these paints.
SOURCE: MY CAMPBELL HAUSFELD DH5300 PAINT SPRAYER WILL NOT SPRAY PAINT.
there are several issues that can cause this problem.
I will assume you have used the sprayer before so that will eliminate an incorrect air cap. The only other issues are paint viscosity, worn parts and the number one cause improper cleaning.
Be prepared for a complete disassemble of your gun. Depending on what you spray any residue can become hard as cement and it only takes a small amount to cause problems.
Below is a link to the manual that gives an exploded view of your gun.
Hope this helps but if not please let me know and I will trouble shoot further.
http://www.cpocampbellhausfeld.com/static/manual/www.cpocampbellhausfeld.com-dh5300.pdf
SOURCE: paint sprayer won't pump
Ok, go to campbel hausfeld web site and download a manual for your sprayer : http://www.chpower.com/webapp/wcs/stores/servlet/XManuals?langId=-1&storeId=10051&catalogId=10001
Find your model number and look at parts view. Pay paticular attention to the inlet and outet valves. They must be absolutely clean to function. These pumps must be thoroughly cleaned when finished.
SOURCE: how much should I thin my paint for use in an
5 % will do.
Regards
Testimonial: "Thanks a lot. I went with 10% and it seemed fine. I'll try 5% on my next project."
