Think last time I did one of them I went in thru ram air intake near light...not sure on yr/model...but I managed to get a new one installed that way after wasting 20 min going other routes
Changing the battery in the remote won't affect the programming, and neither should a dead car battery. I am surprised there is no keyed entry on the driver's door.
You may want to check the built in trio-diode in your alternator. This lets current flow one way when it is ok. When defective, current will flow both ways & this will run your battery down.Take a fluke meter & see if there is excess voltage draining when car is turned off. You can replace the trio-diode or the complete alternator. GOOD LUCK, ROBERT OLIVER
Disconnect the wiring, unbolt the shocks, remove tie rod nut and remove tie rod from control arm, remove and replace the shocks and reconnect the wiring.
BATTERY, AC DELCO Part Number: 75-6YR Product Notes:
[Professional - 6 Yr-Battery]; OE battery is valve regulated lead battery ; Side terminal-Battery CCA; rating 65075 BCI ; 0600 CCA
Per Vehicle: 1; Years: 2003-2003 Corvette
Yea leafs and other debris can get in and cause the noise. Remove the blower, thoroughlyclean the fins and reinstall. This should take care of the noise.
