Question about Hotpoint FFU00 Side by Side Refrigerator
When I try to set a temperature on the freezer it keeps bleeping, the fridge is not working also, there is no noise coming from the appliance but the lights are on, anyone any ideas on what the proble
When I try to set a temperature on the freezer it keeps bleeping, the fridge is not working also, there is no noise coming from the appliance but the lights are on, anyone any ideas on what the problem is?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 23 Answers
Needs new control board,
Posted on Dec 10, 2014
Anonymous
SOURCE:
Anonymous
  • 133 Answers
SOURCE: Frige-Freezer not coming on!
there is really nothing You personally can do to fix it, oyu will have to call a serviceman, i reccommend sears. It is a internal circuit or wire that probably blew and needs to really be fixed by a professional.
Posted on Sep 15, 2007
szwaan
Simon Zwaan
  • 209 Answers
SOURCE: Has been bleeping a while, then fridge got warm, then freezer defrosted!
So the freezing element in your fridge is broken and it's beeping because it gets below a certain temperature ?
Posted on Dec 27, 2007
docjohn174
john gagnon
  • 943 Answers
SOURCE: I have a 10 year
thanks for the question yes it very well could i would pull fridge away from the wall and clean the condenser if dirty makes all the difference especially in that heat thanks the appliance doc
Posted on Sep 24, 2008
Anonymous
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
Anonymous
  • 42 Answers
SOURCE: Fridge freezer has stopped working
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Posted on Jul 02, 2009
Fridge keeps bleeping
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Mar 19, 2016 | Refrigerators
Why is my upright fridge freezer bleeping constantly, both fridge and freezer cooling ok
Model number? Usually that is warning that something is wrong. Example defrost not working properly thermistors are defective, or door open. Need your model number to give you answers
Appliance 911 Sea Breeze
Oct 01, 2015 | Refrigerators
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
I have turned my fridge freezer off during 5 weeks. Since I'm back it's back on again, it cools and the freezer is freezing... but every day it rings and indicates that the freezer temperature (the re
Laurie a lot of people forget to leave the fridge and freezer door open slightly and the water from defrost hiding behind the rear wall of the freezer will keep the inside of freezer and fridge damp this will cause the freezer fan motor to rust and stop air circulation. Can you provide a model number? Thanks John Tripp Appliance 911
Contact me Here
Oct 22, 2014 | Refrigerators
Samsung RL36SBMS top Fridge. The problem is that the fridge has stopped cooling altogether. The electricity is getting to the appliance, the light is on and a low humming noise (fan maybe motor?) can be...
if your freezer is fine, try a total defrost in the freezer and fridge over night and retry,sound like ice is blocking the air duct from the freezer to the fridge caused by the freezer door being left open at some tage of its not going into defrost,if it comes right after defrost but returns in a few weeks then you need a technicn to replace the defrost element
Mar 04, 2018 | Refrigerators
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
Dec 16, 2008 | Fisher and Paykel Fisher Paykel 21768 -...
Too much bleeping
The alarm is caused by either temperature disorder, check on your thermostat settings, or it is being caused by unbalanced level of freon gas in the system, or the door of the freezer does not shut correctly.
Thanks
Nikunj Pattni
nikunj@qool-point.co.kr
Nov 17, 2008 | Liebherr Refrigerators
Dec 27, 2007 | Hotpoint FFM90 Bottom Freezer Refrigerator
Hotpoint FFU00 Side by Side Refrigerator Logo
71 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
