I did some research and I know this can be caused by the wrong driver. I went to the Epson site and downloaded the Epson Stylus Pro 7600 with Ultra Chrome ink driver for windows Xp 32 bit. The computer that is hooked up to this printer is running Windows XP home edition which is 32 bit so I think I have the correct driver (Epson1216.exe. I'm not 100% sure whether I have the Ultra Chrome ink setup or the Photographic Dye setup and I wee they are different drivers but I can't seem to find any information how to tell which printer you have or if it is the same exact printer that can just use different inks. I have PHOTO BLACK and LIGHT BLACK so I believe that means the printer has UltraChrome inks. Does anyone have any thoughts what the problem could be? FYI I am getting this error just doing the "TEST PAGE button after the driver installs. It seems like this should be the easiest thing to print but perhaps that is flawed logic. Thank you!
Might be an idea to try both drivers and see which is best!
In addition to searching for the Model number of your printer, try adding the P/N (part number) which is usually found on the bottom of the printer. I have found that some models of printers can have different drivers especially when they have been manufactured a couple of years apart. When I searched for your printers driver, I came up with a file very similar to yours except that it was called epson12167.exe. Here is the link to that file. I hope it makes the difference:
Epson Stylus Pro 7600 Print Engine with UltraChrome Ink
SOURCE: epson 3000 stylus inkjet not communicating with windows xp cpu
What windows version are you using?
here is the link for available drivers: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14430&prodoid=11356&infoType=Downloads&platform=Windows
SOURCE: EPSON STYLUS PRO 10000
00010014 Pressurization error
Ink supply pressure incorrect
Explanation
The pressure system is determined to be leaking then this message appears and printer is stopped when detection of pressure origin sensor is incorrect at power on initialization or ink supply.
Solution
1. Replace supply pump assembly (including pressure origin sensor solenoid).
2. Check for disconnected air tube.
SOURCE: I am trying to get my epson stylus photo printer
Check out this link, it might help.
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-Photo-830U/Drivers-Support
