How do I check for a blown head gasket on my 1990 Toyota Corolla Wagon?
Pretty much same answer as I gave for 87 Reliant see below. Shops have equipment to do cylinder leakage test. Do basic stuff below before doing last test ...cylinder leakage...which costs $$$.
Main point you are losing antifreeze/water. Check to see if you have water on the dipstick mixed in with oil. If so...probably a head gasket. If oil looks normal..... Before you do any test, tighten every hose connection. Check for loose connection into antifreeze reservoir. Sometimes there are small cracks on top which lets out pressure from cooling system. Look for leaks on water pump and radiator. Look at spot where you park the car...any liquid on floor? Not sure?..Put piece of cardboard under car to see if liquid is dripping from car. No leaks?...Start with a pressure test of the system. The pressure test is simply equipment that replace the radiator cap, a hand pump connected to it then air is pumped into cooling system. You watch the gauge to see if pressure is dropping. If pressure does not drop ..problem is most like a worn radiator pressure cap or stuck thermostat.. Do not buy the kind with button on cap to push down and release pressure. get original type and correct pressure. If overheating still, thermostat could be stuck, replace. Overheating of engine causes vapor lock, bubbles in fuel, which causes car to stall and kill. When cools off, fuel cools down and fuel will flow through fuel system again. Large amount of oil disappearing with overheating also sounds like head gasket or cracked head....Tighten up all bolts to gaskets, look for oil leaks on garage floor or driveway. If engine has developed a miss when running, pull plugs out and look for wet fouled plug. If antifreeze leaking into cylinder...plug tip will be whitish, if oil leaking into cylinder, grimey oil fouled. Do compression test on cylinder that is fouled and that will pinpoint if bad head gasket or cracked head. When doing compression test, radiator cap is removed and you listen to hear bubbles in radiator from the cylinder leaking into cooling system. 87 Reliant not worth pulling engine apart if head gasket or cracked head. Best oil treatment to reduce oil consumption is "Engine Restore" Used on my 58 Impala 348 tri power for 28 years. If I did not add it after oil changes it used oil and smoked....I swear by it for ANY engine after 100,000 miles.
One more thing, after doing cooling system pressure test with engine not running. Start engine with pressure test gaguge still on radiator. Let engine warm up and see if cooling system pressure rises higher. If it does, you have bad head gasket or cracked head. Air from combustion cylinder is leaking into cooling system.
SOURCE: need the cylinder head torque settings on a toyota
Tighten in several passes to 44 foot pounds.
I just wanted to add. Since this is an aluminum cylinder head, I hope you loosened the head in the loosening torque pattern. The pattern opposite of the torque tightening pattern. If not, you stand the chance of warping the head.
Again, since it's an aluminum head, it needs to be checked for flatness. Most aluminum heads need to be surfaced before re-installing.
Tightening torque pattern is as follows:
1.The Drivers side of the engine is the Left side.
From the Front going towards the back; the bolts are numbered 10, 6, 1, 3, and 7.
From the Front going towards the back on the Passenger side; the bolts are numbered 8, 4, 2, 5, and 9.
The Exhaust and Intake Camshaft Bearing Cap bolts go to 9 foot pounds. Tighten gradually. One bolt to the other with so many foot pounds, work back, and forth up to 9lbs.
Camshaft Timing Pulley bolts go to 43 foot pounds. (In a tightening sequence, and gradually)
