Removing the microSD Card
To safely remove the microSD card from your device, you first need to unmount it.
WARNING: On the Android OS 2.3, you can download applications from Android Market and store them
on a microSD card as well as on the device. Due to this feature, skipping the unmount procedure can cause an error because information between the microSD card and the device is not accorded properly. In the worst case, the microSD card can be corrupted or damaged.
1. Press > > Settings>Storage>Unmount SD card.
Confirm your selection by tapping
OK.Now you can safely remove the microSD card.
2.Remove the back cover using the fingertip cutout at the bottom of the cover.
3. Gently press the microSD card in to release it and carefully pull it out of the slot.
Inserting the microSD Card
1. Remove the back cover using the fingertip cutout at the bottom of the cover.
2. Position the microSD card with the label side facing up and slide it into place until it is fully inserted
and locked in place.
Note
Be sure to
use only recommended microSD cards (up to 32GB). Using non-recommended microSD cards could cause data
loss and damage your device
