Belkin N600 DB Wireless Dual Band N Router Logo
A
Anonymous Posted on Oct 19, 2014
Using my mobile phone won't accept my password
When I key my password in it won't connect
Scott P
Level 3:
  • Master 1,087 Answers
  • Posted on Oct 19, 2014
Scott P
Master
Level 3:
Answers
1087
Questions
Helped
262631
Points
2538
Prolly because out the box that router uses AES encryption. You can drop it down to say 64bit from the AES 256bit and most cell phones B network cards will understand 64bit. You will need to basically change the routers security and youtube has a ton videos show you how.
How can I unlock my aurii secret lite. I tried to insert another sim but as I turned it on it asks for Privacy protection password
It can be removed through HARD RESET your aurii secret lite. USE the below method with caution because it deletes all your data & setting in the phone.
At first turn off the smartphone by pressing the Power key for a few moments.
Then hold down Volume Up and Power buttons for a couple of seconds.
When you see the FIREFLY MOBILE logo release all keys.
If the Android Robot appears click Volume Up + Power key.
In this mode choose "wipe data/factory reset". Use Volume keys to navigate and the Power button to accept it.
After that select "yes" and confirm with the Power key.
At the end choose "reboot system now" by using the Power button.
Well done! Your phone will be password-free.
Mar 03, 2019 • Cell Phones
2answers
Too many pattern attempts
alright you need to check if you have used in any gmail accounts while you used you phone,which you can use to reset the password and use a new pattern or passcode.just check above the pattern to see the gmail or forgot password button.
if non worked,try a local mobile shop to reset the phone for you. ;)
Hp dv7 won't connect to mobile hotspot
RUNNIG WIN XP? READ THIS http://www.fixya.com/support/r7858944-working_widows_wireless_networks
1helpful
My router won't accept password that is on printout from when setup
Check the wireless settings of your router. Connect the computer to the router and open the setup page of the router. The wireless settings might be changed. Follow this link to find wireless network key
Won't accept password
Which password? Are you trying to connect to the wireless network. Make sure that you have the correct network password. Open the setup page of the wireless router and check the wireless network key WEP WPA.
If you are trying to open the setup page of the router then try default password admin.
2answers
I want connect a internet to my mobile by wifi the mobile asking the password
Hi. There's a security key to the wifi were you are connecting. You need to ask the owner of the wifi what's the security key. You need to input it before you can connect to the wifi
I have a kyocera loft virgin mobile phone. I am entering all my information to set up my mobile web. When I go to enter my password it only accepts the first 7 of my password and I have 9 characters. So I...
I currently don't have an answer as to why your Kyocera only accepts 7 characters of your password but I have a simple fix that could solve your issue. Just access your email first using a computer then change your password from 9 characters to 7 characters long. In this way, once you set up your Kyocera and enter your email password, it would accept it and would be able to receive your emails.
Hope this helps.
Mar 25, 2011 • Cell Phones
44helpful
4answers
My samsung champ gt-c3303 not supported samsung kies and how can i connet my phone with pc and use internet
my samsung champ touch phone gt-c3303 not connected 2 d internet via pc,how can i solve my problem?
I need a code to unlock my SGH-D415 t-mobile cellphone
HI HERE IS A SOLUTION CAREFULLY FOLLOW IT Warning: Do not enter any wrong unlock unlock codes on your Samsung SGH-D415 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-D415 mobile phone with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-D415 mobile phone is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-D415 mobile phone.
If it does not work, you can try these methods:
Method 1:
2 - ;;Phone;; will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-D415 mobile phone shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-D415 mobile phone.
3 - Compose : #0111*CODE#.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-D415 mobile phone.
Each Samsung SGH-D415 mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-D415 mobile phone at www.mobileunlocksolutions.com. HOPE YOU SUCCESSFULLY DO.... PLEASE RATE ME THANK YOU
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
