Tv is not recognizing any input. Just says "no signal" after trying to connect. Have tried HDMI and AV connections. HDMI cable is brand new, AV connections work on other tv'd in the home. Was working fine yesterday
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
It wont do any good.Some ic has burned up,can be replaced by a professional only.
SOURCE: how can I use my lg lcd tv model m1994a for my ps3
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Testimonial: "ok!!! it is very much helpful...I solved my problem already using this steps...now I can play my ps3 games by my LG lcdtv 19 inches..."
SOURCE: LG tv shows av inputs as black & white
you need to plug all three colors in not just yellow
red blue green need to be pluged in their respective colors
SOURCE: connect tv to cable box with hdmi lead
You will need an HDMI to DVI cable which are available in the shops, even ASDA has one but I don't know how good it is. Or you can buy an adapter that will plug into one of the ends of the HDMI cable and then plug into the DVI socket at the back of the TV. The DVI input is video only so you will need audio leads for sound. These will connect from the output of your source, say, blue ray or sky HD (Left and right audio sockets ) to the audio L/R at the back left of the TV (on the block next to the three component video connections and s-video connections)
SOURCE: "No signal" sign on TV screen using HDMI selector
it sounds like a refresh issue, double check you selector and make sure it fits the refresh of the tv. i had this once with a sharp where the tv was 120hz and the selector was 60 and it created a no signal and when it did come in it was jumpy. if you have a 120 tv then selector should be the same.
SOURCE: Sony Bravia does not recognize my Dell Inspiron 1525
I have the 1525 and you have to do extra steps each time you want the HDMI to be recognized by the Bravia - too bad it is not automatic as it is with some. Anyway what you have to do is have the HDMI cable connected from laptop to TV then go to your desktop - right click on an open area (away from icons), a menu will appear, let the cursor hover over Graphics Options - you'll then see Output To...then you'll see Intel Dual Display Clone...hover over that and you'll then see Notebook + Digital Television...left click on that and you should see your desktop on the TV in a few seconds. If it does not work the first time...get your movie or whatever you want to show up and ready and go thru these steps again...stupidly complicated aye? when it should automatically detect and show...are other TVs like this?
