LG 32LG30 32 in. LCD HDTV Logo
A
Anonymous Posted on Oct 18, 2014
<!-- from fixya rte -->How to turn off store Demo mode LG TV - LG 32LG30 32 in. LCD HDTV
Kimberly Bridges
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 08, 2019
Kimberly Bridges
Contributor
Level 1:
Answers
Questions
0
Helped
2426
Points
How do u make store demo go off on a lg plasma tv
  • Kimberly Bridges Nov 08, 2019
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Oct 19, 2014
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14981503
Points
237762
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Nov 30, 2009
SOURCE: 42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
My lg tv is stuck on store mode how do i get it off
There will be a demo mode selection in your settings or options. Turn this off.
There is a number of pop ups onthe tv stations on the side and the top
It seems like your Tv is on demo mode go to the menu screen select option and search for tv mode turn it from store/demo mode to house mode also check that if demo in on to turn it off
hope i was helpfull
11helpful
How to remove auto visualisation n digital noise filter on and digital noise filter off features from screen of samsung lcd 21 inch....this feature is always there on the screen..........
My TV had the same problem and I have managede to get rid of it. The solution is very simple. This displays mean that your TV is in the " Store Demo" mode and any changes you make will last only for 30 minutes and when the TV is turned off the settings will change back to the normal. Whether you TV is in the "Store Demo" mode can be confirmed by pressing the "Info" button on the remote and you will see that "store demo" appears on the screen. To change this mode to the "home mode" you will have to press the "Volume button" on the TV and when the volume sign appears on the screen then you will have to press the "Menu" button on the TV (not on the remote)and hold it down for about 7to 10 seconds. This changes your TV mode from "store demo" mode to the home mode. Confrim whether the store demo mode has been put off by pressing the "Info" button on the remote to see whether the store demo sign appears on the screen. The store demo is set by sales persons in the shops so that any demonstratation/changes that they make while showing to customers will be temporary as the settings revert back to the original.
5helpful
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
52helpful
2answers
Digital Noise filter off , digital noise filter on and auto visualization is always displayed in my Lcd samsung series 4 even though i turned it off in Picture options , digital noise filter is changed to...
My toshiba 36in crt tv's demo mode keeps turning it self on
Since I do not have your tv model number so can't be specific, check Demo mode option in Menu and turn it off. Some tvs have selection like Store/ Display and Home mode, store or display mode is demo mode so set tv on home mode to turn off demo mode.
Let me know model number of your tv if you have additional question.
Thanks.
1helpful
2answers
Tv turns off after 7=8 min.
Sometimes they come automatically on demo mode chesk if in your main menu it has a demo mode it may also have a sleep timer st check that also.
Store Mode is ON.
for Bravia's.. To turn off the demo mode, press and hold the MENU button on the TV for more than 10 seconds. The message Demo mode: Off will appear on the screen.
Let me know if this helps.
A Big Problem
If you're talking about "demo mode", this is from the manual:
Demo Mode
This TV has a demo mode for use in retail stores. To turn the demo mode On/Off, press the following buttons in sequence:
MENU, 0, QV, 0
Hope it helps.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
