Frequently the display reads F-10 and an alarm beeps when I turn on the oven
Good Afternoon friend, thanks for your post!
Based off the information you have provided your range is displaying an "F10" error code. "F10" typically means that your wall oven has detected an issue with the runaway temperature (overheating).
Sometimes resetting your appliance can correct this issue but in the case that it does not and you still receive that error code I would recommend having a professional come out to properly diagnose and repair. At that time you could be having an issue within RTD (Resistance Temperature Detector) sensor probe or the EOC (Electronic Oven Control) having a professional come out would reduce the cost of unnecessary parts. I hope this information is helpful. -Matt
SOURCE: F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F0 & F1
EOC (Electronic Oven Control) failure
Replace Electronic Oven Control
F2
Oven too hot
Check Bake function, if OK, replace oven temperature sensor
F3
Oven temperature sensor open
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
F4
Oven temperature sensor shorted
Replace oven temperature sensor
F5, 6, 7
F8
Lock switches
Check switches and replace if necessary
SOURCE: My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
SOURCE: Kenmore Electric Range
F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
SOURCE: Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC (Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
SOURCE: Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
