Leica Disto A6 Laser Distance Meter Logo
A
Anonymous Posted on Oct 18, 2014
Does not measure distance
When switched on and distance is measured the length, the mainline display remains blank.
Gary
Level 2:
Champion:
  • Expert 210 Answers
  • Posted on May 16, 2016
Gary
Expert
Level 2:
Champion:
Answers
210
Questions
Helped
65862
Points
410
Put in new batteries, clean lens, and calibrate. If this does not work, type " Leica Disto A6 Laser Distance Meter user manual " into computer search engine. It will bring up sites for manual.
2answers
How do I measure ohms in distance
Ohms is a measure of resistance as in an electrical resistor. Wire also has very small resistance but a long length of wire can equal a fair bit of resistance.
Now, to your question, you can't measure ohms in feet - unless you know the resistance per foot of wire (as an example).
Throttle Cable - Idle Cable
Measure the distance between both ends of the cable. This does not include the ends (Ball or round ends) on each of the cables to get the measured length of the cable..
Mar 19, 2014 • Motorcycles
How are you supposed to know if two shapes are similar if there aren't on a grid.
Use a ruler to measure the lengths of the sides and a protractor to measure the angles. The scale factor is the lengths of one divided by the lengths of the other.
Seats height
Hi, here is how to determine your seat height.
Measure your inseam length by standing barefoot against a wall, use a book to press up as high as possible between your legs, and measure the distance from the top of the book to the floor.
Take that length and multiply that with 0.65 to give you the distance from the top of your saddle down to the center of you BB axle, where your crank goes through. The distance indicated by A on this pic.
Hope that helps!
3answers
Diference between yd and cubic yd.
A yard is 1 dimensional so just a straight line.
A cubic yard is 3 dimensional so imagine a box with all sides being 1 yard long, the volume of this box is a cubic yard.
The ads for this device state that it uses the Pythagorean theorem to figure the distance of a 3rd side, if you can measure the other 2 sides. I How do I use this feature?
1) There is a big difference between Bosch promo manual and Bosch operation manual:
2) Online promo manual says: Combined Indirect/Pythagoras for measuring total height from a distance
http://www.boschtools.com/AboutBoschTools/RequestProductLiterature/Documents/2010%20Catalog%20PDF/2010%20Measuring%20Tools.pdf
3) Online operation manual shows no instructions for Pythagoras measuring.
And shows no button for displaying E value or height.
http://www.engineersupply.com/images/bosch-tools/Bosch_Digital_Distance_Measurer_130k_User_Manual.pdf
4) Operation manual shows:
Length Measurement** and tells you to measure the height while promo says tool will calculate height E
Area Measurement*** shows rectangle only and not triangle
Volume Measurement
Area or Volume
Rounding of Large Calculations
Continuous Measurement (Tracking)
5) I would contact Bosch directly:
http://boschtools.com/Service/ContactUs/Pages/default.aspx
6) Until you get satisfaction from Bosch, the Bosch device gives precise menasurements that can be entered into a Pythagorean calculator online, which defeats the purpose of a jobsite tool: But you can access online calculator via cell phone while on jobsite.
http://www.analyzemath.com/Geometry_calculators/pythagorean.html
2helpful
I want to convert the distance/speed from miles & mph to km & kph to assess the distance and speed after running?
Manual is here: http://www.sportline.com/manuals/370.pdf
SETTING USER DATA The Sportline TraQ is equipped with an advanced Pedometer that measures Steps, Speed, Distance, Calorie Expenditure and Exercise Time. In order to ensure exercise data is as accurate as possible, you must enter your personal profile. 1. Scroll to User Data (display will read AGE) by PRESSING the MODE key. 2. PRESS the RESET key to enter the programming sequence. 3. Adjust Age by PRESSING the INFO key. PRESS the MODE key to Advance to Set Weight. 4. Select Weight Units (LB or KG) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 5. Select Units of measure (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 6. Select Stride Length Units (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 7. Adjust WALK Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set RUN Stride Length. 8. Adjust Run Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set daily step GOAL. 9. Adjust daily step GOAL PRESSING the INFO key and advancing to next digit by PRESSING the MODE key
1helpful
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
How do I measure the area of a room using a
it is still length times width. the laser must turn 90 degrees or the measurements will be off slightly. Im not sure which laser you have but the one i use says store on one of the buttons and i use it to store distance one
Top Leica Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Leica Measuring Tool and Sensor Expert? Answer questions, earn points and help others
