The audio description comes on randomly.Its mostly when watching programs I have recorded.
SOURCE: looking for parts list and or service manual for
Tries websites like Shopjimmy.com,Ebay.com.To buy a whole refurbish LCD inverter board.No,body will sell it to u in by componnents to componnents.
SOURCE: I can not program my
Hi, Turn on the TV. Locate the "Set" button and the "Power" button on the remote. The "Set" button is located directly below the "0" button. The "Power" button is located in the top right corner of the remote. Press and hold the "Set" button and the "Power" button simultaneously. This illuminates the LED icon located at the top of the remote control. Press the button for the device you want to control in this case "TV" Point the remote at the TV, and press the "Channel Up" button on the remote control followed by the "Power" button. This performs a quick search for the device's code. Press "Enter" to store the code once the device turns off. Alternative Automatic Programming Please do leave a vote for the solution. Many thanks
The only way you will get this remote to work with this TV is to have it automatically scan through all the codes it has in its library whilst pointing it at the TV. I have included the instructions on how to do this below.
Be aware that not all remotes contain the relevant code in their library for the device concerned. In the event that that the automatic scan through the entire library of codes fails, the remote is not compatible and cannot be used with this set.
The only other solution in this case is to purchase another universal remote that has definite compaibility with this RCA TV model. However, hopefully this will not be necessary.
Follow the steps below. There are two variations with this remote on automatic scan. Use the one that applies to your version;
1. Turn on the TV.
2. Press and hold the corresponding button on the remote control (TV, VCR, SAT, DVD) until POWER INDICATOR illuminates. The remote control is now in programming mode.
3. Press POWER button on remote and release . The POWER INDICATOR flashes once and stays on indicating the unit is in Power scan mode.
4. Press CHANNEL+ or CHANNEL- repeatedly until the device turns off.
5. When the device turns off, press ok to store the code.
SOURCE: I need an owner's manual
Right-Click on this link and click save target as to download the complete owners manual
http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2842852/dvr620_dkvr60_om_e.pdf
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
