Elec are coming on just wont start
Many motorcycles that are newer have a built in safety device that keeps the bike from starting when the battery is too low to keep from burning out components from running low on voltage. Can you hook a battery charger to it and have it start or is it just turning over and not starting? Without any details about your problem it is hard to troubleshoot. Has the bike been ridden recently, has it been setting so the carb is gummed up, is it fuel injected, does it have an electric fuel pump?
Testimonial: "hi it had a new battery it will start if you put a screwdriver on the soliniod but all elec are fine just when you try to start with key the elec come on but nothing he tryed looking at all wiring they seem ok it had a new soliniod on friday"
This may sound like a stupid answer but I have seen it happen several times. Is the kill switch in the ON position. Turn it to run and the key and starter will be activated. If that is not the case then check to see that voltage is passing from through the iginition switch and kill switch to the solenoid. Start at the solenoid and work back through the switches to the positive terminal of the battery.
anyhelp would be great full new battery new soliniod new fuses still nothing
