Restart works normal until after 'waiting for background programs to close' then black screen and i am forced to hold down manual start button for it to fully turn off.
If the PC shut down normally in recent past, try a system restore point for the most recent date the PC operated normally. Just go into the Safe Mode and select the restore option, then select restore point.
Before shutting down your system click on any programs still running and shut them down. This will cut the time for normal shut down to take place.
You could also run a hard drive diagnostic to see if it has any errors. There might be some if you don't let the computer shut down itself. Restarting can also cause the programs to become corrupt, if they didn't shut down right. Running a defrag on the drive will also help it shut down quicker.
Look on the net also for information on getting your PC to shut down quicker.
SOURCE: acer aspire 5715z/5315, turned laptop
back up your important file,through accessing safe mode.pres f8 so that you can go to safe mode.then get the important file.
reinstall your OS so that it can run normally.
enjoy...............
SOURCE: Computer start up problem
Capture the message that is displayed on the BSOD. There will be a bunch of numbers that will tell you what is wrong. I would open the side and re-seat the RAM and do a general cleaning of the fans.
SOURCE: my desktop background disappears and turns black evrytime after i reboot my system....kindly help
is your OS registered or activated? i had the same problem with my desktop and not until i activated my OS did i solve the problem.
SOURCE: Acer Aspire M5641 Will not boot to Windows
boot from CD/DVD Drive with windows installation disk and do a repair
SOURCE: acer aspire x1301 u9052 wont boot
Im not 100% sure about this but may i suggest you change the CMOS battery on the Motherboard, there is a chance that it is flat its a very common battery that you can purchase from your local store, but just change that and let me know what happens
