Master
- Posted on Oct 19, 2014
Re: Need driver for win 8.1 D33006...
Not finding your model number at the Gigabyte site. Please check and confirm it's Gigabyte and that you have the correct model.
I would install the board. Windows will attempt to match a driver, and will tell you what chipset you have. You should be able to use a "generic" chipset driver.
GIGABYTE D33006 MPCIE1 GV-RX195P256D-RH DUAL DVI-I GRAHICS CARD
this? real name?
w7 is max but go back every year to see if that changes but did not 8 year later
all are at gigabyte.com but only or supported (not told) OS.
w8.1 is newest then, so is not w10 at all
video cards have full complex model numbers
to support newer GPU versions and more VRAM. and drivers for them so use the full model tag data
to get a match at makers site, Gigabytes
the F8 W7 limphome drivers work but are lame. only full blown driver from OEM is best, and will not crash.
older driver fail.
