Manual doesn't mention the method of saving to the internal memory of the product or on the company website.
Usually, the camera saves to internal memory when no card is present. Internal memory is not large. More for holding a photo or two until you realize there is no card there. When you do save to internal memory you then need to transfer the images to a card, or plug your camera into the computer and transfer the images that way. Hope that helps.
SOURCE: Move images saved to the internal memory to the optional xD-Picture Card
The images saved to the internal memory can be copied to the xD Picture Card, but you cannot copy images from the xD Picture Card to the internal memory. Before you choose to copy the files to the xD card be sure that there is enough room on that card. To copy the images to the xD card make sure the camera is powered on, then and press the menu button. Use the down arrow key to navigate through the menu to the BACK UP feature. Use the right arrow key to enter the Back Up screen and select YES to copy the images to the xD card, or NO if you choose not to coy the image files.
The images saved to the internal memory can be copied to the xD-Picture Card, but you cannot copy images from the xD-Picture Card to the internal memory.
SOURCE: Insignia digital photo frame won't recognize some .jpgs
When you save in Photoshop make sure you select "Baseline ("Standard") on the JPEG options when you save. That should fix the problem for you. It did the trick for My Kodak SV710 digital frame which wasn't displaying images I had edited in photoshop.
SOURCE: save from internal memory to memory card?
On play mode, press MENU, on PLAY tab-->COPY-->BUILD-IN->CARD, press SET,then wait until the "Busy...Please wait.. disappears.
SOURCE: Transfer internal memory to memory stick. Olympus camera
Place a memory stick in the camera. Next, go to MENU, then press BACKUP. This will save your internal images to media card.
