C9401 means the lamp that the scanner uses isn't turning on.
Thread Konica minolta bizhub C351 error code C9401
SOURCE: Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
SOURCE: SMB Scanning to a Macintosh
SMB can be a bit tricky on Mac as the aliases etc, & paths can easily overwhelm the MFP. Try FTP as a better alternative. Use "Locations" on Mac to setup a static ip# they can switch to when scanning. I have found the KM machines a bit more fussy than Canon with regards to SMB as you can usually browse better on the Canon devices. I have seen the "Reference" browsing on KM allow you to see into the Mac yet will not allow scanning to the set location. Our KM reps always recommend using the ip# of the device vs Netbios name. To me that sort of defeats the point of using SMB anyway. Scan to PC over SMB seems ok to computer Netbios name as long as DNS is registered & working OK on the LAN & WINS is properly configured as well.
SOURCE: Konica Minolta Bizhub C352 error code C-0204
I had the same recently.
Problem is caused by a paper which stuck behind the paper tray. It
happens when You put to much paper od while moving (for example).
Solution: take out the paper tray 1 and 2, remove the paper from the
space behind the trays.
Pixel
www.mojito-networks.com
SOURCE: Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
si
SOURCE: Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
